Problem on connector
When I am trying to connect (locate connector) between line and frame object in Plant simulation. I am getting error,
"The frame does not have a suitable interface"
Tecnomatix v12.0 32 bit.
Do I need a any different package for ?
Re: Problem on connector
just include interface objects into the frames for entrance and exit connectors.
you find the interface in the folder MaterialFlow in the class library (you dont need another license)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Yes found it many thanks..
