02-05-2016 03:01 AM
Good morning Everyone,
Today, I tried to copy the format data of the 3D Animations table into another table. It does copy the format data. However, it only copies the data of the outer table. That is, the table with 2 columns with type String(name of the AniPath) And table(inside which are the co-ordinates of the animation path to be set). It does not copy the format data of the table inside for which the type should be real. Is it just me, am I doing something wrong or is this a bug?
Thank you for your time. Have a wonderful day.
-Simpulse
02-05-2016 04:30 AM
The table of animations from which you are copying the format has no common format.
This is because different types of animation paths have a different format.
As a result, the formats of the subtables is considered part of the content (because it can change for every table) and hence they are not copied with the main table's format.
