Problem with connection text file.
Hello. I have small problem with connection text file.
In method init i have:
datafile.readFile("data.obj");
and when I start proces data from file goes to table but all machines dont moves and when i reset simulation and dont move data from table then everything works. What could be the reason for such thing?
4 REPLIES 4
Re: Problem with connection text file.
maybe it takes a while to read the data, this may cause some problems in initializing the simulation. What exactly happens?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
This is my model, when I start simulation data from file goes to table "Źródło" and this is ok, but simuation works without the elements and then time is weird
The source is faster in creating the events in the eventcontroller then your init-method. So the source don't find at the very start of the simulation entries in the table. You can solve this problem, if you use the reset-method instead of the init-method to fill the delivery table of the source (just rename the init-method into reset).
Steffen Bangsow
web: www.bangsow.eu
it works, thank you very much
