Problem with move operator
Hello community,
I'm new to plant simulation and stuck to a simple problem I guess.
The Layout i'm trying to simulate has a loop structure for the first stations and after entering the 2nd time a specific station the MU needs to move to the next steps.
I gave the MU the user defined type : integer and the value : 1
And as exit method for my material flow i wrote the method:
is
i:integer;
do
       if  i=1;
       @.move(Station_1);
        i:=i+1;
else
        @.move(Station10);
end;
The Error i get says that "move is not allowed in formulas"
I hope my problem is clear and you can help me.
Greetings
Fabian
Re: Problem with move operator
there is a syntax error in your method:
is
i:integer;
do
       if  i=1 then
           @.move(Station_1);
           i:=i+1;
        else
            @.move(Station10);
        end;
end;
This method will only move to Station10. Startvalue of i is at each call zero, so the else branch is selected.
If you want to increment i with each call, you should use a global variable i instead a local variable.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you for your fast help.
Without changing the global variable it still tells me that move ist not allowed in a formula...
How can i change the variable to a global?
Also in the data type of the MU and create a method for the start value 1?
can you post your model? I guess there is another failure in your method.
You find the global variable in the class library; folder information flow. Just insert the variable block into your frame, rename it to i, change the data type and delete in your method the line
i:integer;
Steffen Bangsow
web: www.bangsow.eu
Hello Steffen,
Now it works perfect! Thank you so Much!
Und auch auf deutsch, vielen lieben Dank Ihnen!Smiley Happy
Okay sorry,
i post my model...
