Problem with movement of parts
Builder
Builder
Hi community
I have the next problem:
In the attached image you can see that the part type "blue" is going out to OP_40, but here is my problem, since the last part of "red parts" batch is not go yet from OP_30 becuase it is failed. The issue is when the blue part enter to OP_40 it triggers the setuptime before the last part.
How can I program a little code to avoid the new part go out from buffer (L2) and it waituntil the OP_30B is available?
it could be this a solution? or is there another alternative?
This could be useful when another part type enters to line and prevent them from mixing
I hope your can help me and give me suggestions
Charly Regards
Re: Problem with movement of parts
to control / choose what parts enter a station, you can use the pull controll
Builder
Builder
Hi Simulator
Could you share an example model with me?
Charly
Hi!
Here's one possible implementation to prevent mix on conveyor.
Regards, Vladimir.
Builder
Builder
Hi Vladimir!
Thanks for your reply and your help
It works perfectly
Charly
