Re: Problem with project
Thank you for sugestions, it was very helpful and everything works how I want.
I would like to change one thing in my model. In the figure below I have my current working scheme and what I wont to change.
How should lokk like waituntil, because I want to gantry waited until the end of the process and then picup the element and move.
Is some formula waituntil SingleProc processing end or something ?
you could remove the exit control from the waste-buffer and call the cran, if you unload the component on the drain...
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I don's understand. I remove the exit control from waste-buffer and what I should do?
just call the method onExit3 at magazyn_elementow instead at Blachy_lub_skrawki
Steffen Bangsow
web: www.bangsow.eu
I do it that but i have i method onExit2 that situation
so not everything go to Magazyn_elementów, some parts move to Odpadki.
are there going also parts from Blachy_lub_skrawki to Odpadki?
Steffen Bangsow
web: www.bangsow.eu
But i some moment model locks up:
you need also to call the crane in the entrance control of Odpadki (if Blachy_lub_skrawki is occupied) to complete the cycle, if the element is transported to odpadki
Steffen Bangsow
web: www.bangsow.eu
thank You very much for all help
