Problem with worker doing setup and repair at same time
Hello Community,
I am trying to simulate a simple assembly line, where workers do the setup and failure repairs as required(please look in the model file attachment).
But the model is blocked when I run the simulation. The worker is not involved in processing at all as the machines are automatic, but the worker is required for setup and failures removal.
Can anyone give me some input in understanding, how and what the problem is ?
Thanks in advance!!!
Re: Problem with worker doing setup and repair at same time
you need to set the set-up importer to "Can be interrupted and drawn off" and you need to set a higher priority to the failure importer (so the broker can interrupt the setup to fix failures)
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you Mr. Bangsow.
