Process Capacity, parallel, batch
Dear all,
I'm new on Plant Simulation, i have one issue would like to get your support:
1. I have two assembly line work in parallel.
2. After parts are assembled, it need test.
3. Each room test can perform test 2 part at same time. That mean need wait assembly to have 2 parts.
3. I have 4 same Test rooms work in parallel.
4. Parts after test need store till reach 20 parts.
5. Painting room do in batch 20.
Please kindly support how to set up this simulation.
Tks,
Re: Process Capacity, parallel, batch
Hello Vu,
you want to create batches for 2 or 20 parts.
The gathering of parts is usually modelled on buffers, which are equipped with an observer of numMU. Depending on the value of numMU the attribute ExitLocked of the puffer is set.
Peter
Hi Peter,
Thank for your prompt support,
Actually I want simulate whole process.
Tks.
