Process suggestion (debris handling)
Hi everyone,
I am in a situation where I need to simulate a process involving some kind of debris lumps (ceramics).
I have some "sources" of debris being transported through a series of devices which break them into smaller pieces (make crumble) the initial lumps. Eventually the product becomes a fine kind of sand.
I may have two types of “sand”, white and black.
After passing through several stations, the final sand is divided into Black or White.
Can someone please recommend a type of simulation prototype (a small example please, I need to take is to a bigger level but I want to get an idea of how to proceed).
Additional info: I know production rates and weight of each debris type.
3 REPLIES 3
Re: Process suggestion (debris handling)
you can use the fluid library to create your model.
To model the crusher you could use a fluid drain and a fluid source. Crushing means delete the old flow and create a new one with a new material (with a higher density - lower flow rate) this you can make in several stages.
Have a look in the seperator in this example:
http://www.bangsow.eu/detail_en.php?id=696
you can make the crusher in the same way, just with one exit.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I have made an example:
https://www.bangsow.eu/detail_en.php?id=770
Steffen Bangsow
web: www.bangsow.eu
Thanks a lot, now I have an idea of how to proceed.
