Re: Processing Times with Table
I do increase those before i use them to get the times out of my table. They should work.
My problem is that the table can't be found.
since the tableFile is in the top frame and your stations in the sub-frame, you need to specify the path of the table
e.g.
root.MZ[...]
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
It does now find the table but it tells me that the left and the right side are not compatible.
Does it have anything to do with the way i wrote the times? (hh:mm:ss)
yes, it returns a string, you need to convert it to a time format
str_to_time(MZ[@.name,@.rüstzeit])
Steffen Bangsow
web: www.bangsow.eu
it finally works.
Thank you very much!
