Protect frame
Good afternoon,
I'm trying to protect a frame with a password, using the method shown below. However, the book where I've found this says that I can put this method on my frame:
"Create a Frame protectFrame and insert a method (TOOLS > SELECT CONTROLS > OPEN). "
is
input:string;
pass:string;
do pass:="xyz"; input:=prompt("Password"); if input = pass then .models.protectedFrame.openDialog; end; end;
The method works, however I can't find the menu (TOOLS > SELECT CONTROLS > OPEN) where I can connect this to my frame. I'm using PS version 11.
Does one of you guys know how to solve this?
Re: Protect frame
try the F12 key in the frame, this should open the dialog
remark: you can also encrypt the complete model --> main menu --> Tools - encrypt model
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: Protect frame
That is what I was looking for, thanks!
