Pull Count MUs and move
Hi everyone,
I have a question regarding my pull model.
I am now struggling with converting my Pull model from Single Part Flow to Batch flow. My pull signals are sent to two tables where the name of the parts are registered, when they are available in the buffers, immediately they are moved to either Production or Transportation.
What I would like to do is to make them wait and count in those Pull Tables and move them when they reach a fixed amount.
First of all, I think I can assign global variables to each parts and count them till let's say 5 and then delete them from the table by moving them to the next station.
But lately, my code checks all the buffers and if the part is available, it moves the parts to the next station.
A count loop could be used, for example when I reach the amount it will go back to 0 and start counting the set amount again.
CountA := CountA +1;
if CountA= 5 then CountA:= 0; "
Which command or object is good  for that, or is there a small example where I can see how to count the part numbers which appear in  a table and wait until the required amount is reached then deleted and moved to the next station ?
Thank you very much,
Erkan
Re: Pull Count MUs and move
you could try an observer for the attribute yDim in the table; it is called after each change of number of entries in your table; the observer method has a parameter oldValue, so you can check, if the value is increasing or decreasing.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Dear Steffen,
Thank you for your quick answer. My goal is actually to control the variable.
To be more spesific,
The parts are seen in a table as strings, but if they are available in the buffer, they are immediately deleted. My goal is to keep them appear until they reach a certain amount ( e.g. 5) and then move as a batch.
I think with the observer, I can only see the number change, right ?
Erkan
the observer for yDim reacts to changing in entries (lines) of a table
how do you count the available parts?
Steffen Bangsow
web: www.bangsow.eu
for local k:=1 to RAW.dim loop --cardfile with all buffers ( Buffer 1,......,9)
    --check, if the part from the order-table is available
	  if RAW.read(k).occupied and PullTable1[1,i] = RAW.read(k).cont.name then
		RAW.read(k).cont.move(Produce); -- available parts are sent to production
		PullTable1.cutRow(i);
        exitloop 2;
    end;
  next;
Here is the code for my pull logic. I am using the card file, with the signal coming to my pull table from a source. Now there is, single part flow so whenever the part is available, they are moved and deleted from the table.
I would like to keep them until they reach for example 5, in my pull table and then move. That's what I was asking about if the observer can keep them till they reach the required amount and then move them all together.
Erkan
you could use a second cardfile to "remember" the parts you want to move, until you have 5:
    pullTable2.append(RAW.read(k).cont);
    exitloop 2;
  end;
next;
if pullTable2.dim = 5 then
  while pulltable2.dim > 0 loop
    pulltable2[1].move(produce);--simtalk 1.0 only
    -- may be you need to wait here
  end;
end;
Steffen Bangsow
web: www.bangsow.eu
Dear Steffen,
Thank you for your answer. I have implemented the code to my model, but the questions I have right now are;
- I have put a cardfile and I see how many parts were moved but I suppose it counts the number of parts (objects) through their column. I am supposed to move when each part is 5. For example;
Part A : 5 --> move
Part B: 5 --> move
So in this case I have to modify the code for each part ?
- You have a comment saying that I have to wait. What do you exactly mean by that ? Can wait be done with waituntil in this context ?
Erkan
if you "collect" different parts, you could use for each part one cardFile (pullTable)
if you move to a buffer or a line, plant simulation need a time to "shift" the parts foreward; so you need to wait a little time between the move commands (e.g. wait(1)) in the loop, otherwhise the move command fails (return false)
Steffen Bangsow
web: www.bangsow.eu
for i:=1 to PullTable1.yDim loop
	inspect PullTable1[1,PullTable1.ydim]
    when "Part1" then
	Part1Pull.append(RAW.read(k).cont);
	when "Part2" then
	Part2Pull.append(RAW.read(k).cont);
	when "Part3" then
	Part3Pull.append(RAW.read(k).cont);
	when "Part4" then
	Part4Pull.append(RAW.read(k).cont);
	when "Part5" then
        Part5Pull.append(RAW.read(k).cont);
	when "Part6" then
	Part6Pull.append(RAW.read(k).cont);
	when "Part7" then
	Part7Pull.append(RAW.read(k).cont);
	when "Part8" then
	Part8Pull.append(RAW.read(k).cont);
	when "Part9" then
	Part9Pull.append(RAW.read(k).cont);
	end;
    exitloop 2;
  end;
next;
if Part1Pull.dim = 5 then
	while Part1.dim > 0 loop
		wait(1);
    Part1Pull[1].move(produce);--simtalk 1.0 only
  end;
  end;
  if Part2Pull.dim = 5 then
  while Part2Pull.dim > 0 loop
   Part2Pull[1].move(produce);--simtalk 1.0 only
  end;
  end;
  if Part3Pull.dim = 5 then
  while Part3Pull.dim > 0 loop
   Part3Pull.move(produce);--simtalk 1.0 only
  end;
  end;
   if Part4Pull.dim = 5 then
  while Part4Pull.dim > 0 loop
   Part4Pull.move(produce);--simtalk 1.0 only
  end;
   end;
    if Part5Pull.dim = 5 then
  while Part5Pull.dim > 0 loop
   Part5Pull.move(produce);--simtalk 1.0 only
  end;
	end;
  if Part6Pull.dim = 5 then
  while Part6Pull.dim > 0 loop
   Part6Pull.move(produce);--simtalk 1.0 only
  end;
  end;
   if Part7Pull.dim = 5 then
  while Part7Pull.dim > 0 loop
   Part7Pull.move(produce);--simtalk 1.0 only
  end;
   end;
   if Part8Pull.dim = 5 then
  while Part8Pull.dim > 0 loop
   Part8Pull.move(produce);--simtalk 1.0 only
  end;
   end;
   if Part9Pull.dim = 5 then
  while Part9Pull.dim > 0 loop
   Part9Pull.move(produce);--simtalk 1.0 only
  end;
   end;
Here I have thought of this code, and for only one part 'Wait(1)"is implemented. But the problem I am facing here is all card files are the same. So I could not succeed to distinguish the names through separate card files.
Another issue is , I have set the MUs as objects in card file but at the end of the name of the MUs there appears really high numbers. I am giving an example for it.
Best Regards,
Erkan
You can shorten your code using a variable:
local partname:string;
				partname:=RAW.read(k).cont.name;
				--enter into the cardFiles
				str_to_obj(partname+"Pull").append(RAW.read(k).cont);
			end;
			if str_to_obj(partname+"Pull").dim = 5 then
				while str_to_obj(partname+"Pull").dim > 0 loop
    				(str_to_obj(partname+"Pull"))[1].move(produce);--simtalk 1.0 only
					wait(0.01);
  				end;
  			end;
		next;
	next;
one wait is sufficient, it is inside the loop
to check the names click in the cardFile with the right mouse button on the reference --> open object; here you can see the name of the object;
The last number of the reference of the MU is its id (instance number).
You should check the names of your MUs.
Steffen Bangsow
web: www.bangsow.eu
