Pull MU's from a Buffer
I have a buffer which has 1000 A Parts and I need to pull only 100 A parts / day.
I wanto pull these parts based on my daily demand (at drain). How do I execute this?
Please help. Thanks in advance.
Sharad
Re: Pull MU's from a Buffer
Hi Sharad,
you could introduce a method as a exit control for your buffer that limits your work in process to 100 in between your buffer and drain.
Example of how the method could look like:
var CurrWiP, LimitWiP : integer
LimitWiP := 100
CurrWiP := buffer.statnumout - drain.statnumout
if CurrWiP < LimitWiP
    @.move
else
    Waituntil CurrWiP < LimitWiP prio 1
    @.move
end
Regards Johan
Thank you for your inputs Johan.
