Question
 Hello, I am  a student at West Pomeranian University of Technology as my master thesis is in progress - it's target is to apply the theory of limits for a company.I ought to create a simulation's model that consist 19 machines and 5 variousproduct/articles to be machined there. All of the 5 products are machined at the first machine and thier processing times differ.  I seek for the method to set up each processing time for a particular product, so that the product after the first one (which is also going to be machined at the same machine), would be described with another , individual processing time? Am I able to set it up?
3 REPLIES 3
Re: Question
Hi Papica,
you can specify a type dependant processing time by choosing "List(Type)" for the processing time of your station. Then you enter the path to a table which contains in the first column the type (name) of your product and in the second column you enter the processing time.
Please have a look at the attached model.
Ralf
Ralf
Re: Question
Thank you for your help.
I have one more question:
How to adjust each product's amount per batch? For example the "A" model should provide machining of 20 products, but for "B" model it is 30 products. How may I set up the simulation so that the "B" model will be machined unless the "A" model batch is completed?
Papica
Re: Question
Hi Papica,
this really depends on your actual material flow.
You might want to close the exit of the station where the B parts are coming from until all the A parts are processed. (Attribute 'ExitLocked' in SimTalk).
Or you could use the pull control to decide which parts are allowed to enter the machine.
Did you have a look already at our examples collection?
(Start Page -> Example Models -> Small Examples)
This is a collection of small examples which demonstrate solutions to typical problems.
Ralf
Ralf
