Random numbers.
Can any one tell me that, when exactly we can use the uniform for processing time and what is the start, stop..??
Re: Random numbers.
Hi Ibrahim,
please look at the index of the help: Distribution > Uniform.
There is also described the frequent application. If one says that the processing time is between  1 and 2 minutes and there are no additional information then the uniform distribution is recommended. You will choose Start 1:00 and Stop 2:00.
Peter
Re: Random numbers.
Thank you peter..
