Re:creating Mus on container
Builder
Builder
Hello Everyone
I am new to the Technomatix. Could anyone let me know How can i create MUs on the container.
Source--Parallelproc --buffer--drain. this is my factory.
I want to delete the Mus coming from source,then create container on buffer,then 3 new parts on container.
I wrote the following program
is
do
Deletemovables;
.MUs.Container.create(buffer1);
.MUs.Sub_assemblies.Main_frame_red.create(.MUs.Container);
.MUs.Sub_assemblies.Anchor_winded_220_720.create(.MUs.Container);
end;
But new parts  are creating separately, not on Container
How can i write program for this?
4 REPLIES 4
Re: Re:creating Mus on container
the destination of the new MUs should be the new creqated container:
is
do
  @.deleteObject;
  local c:object:=.MUs.Container.create(buffer1);
  .MUs.Sub_assemblies.Main_frame_red.create(c);
  .MUs.Sub_assemblies.Anchor_winded_220_720.create(c);
end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Builder
Builder
Thank you very much.
I have one more doubt that,
for example i want create 2
how can i specify the number in the program?
one way: copy the command how often you need it or  you can use a loop
(see help)
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
Thank you for your help.
