Re:parts to the store
Builder
Builder
Hello everyone
I have 9 different parts which comes to the store in a mixed order and they should move to the three successors.
I am weak in programming. could anyone help me please.
I tried to write like this to place the part in a particular place
If name:= Mu.a then
@.move(store.pe(1,1));
if i want to remove the part immeadiately and move to desired successor, what can i do?
19 REPLIES 19
Re: Re:parts to the store
what is your Plant Simulation version?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Builder
Builder
i am using version 12.0
i have seen some examples and tried "find part " but it's not working.
is there anyway to do it?
Thank you very much
findPart is a new function in version 12.1;
here is a older example from me:
http://www.bangsow.de/detail_en.php?id=510
the easiest way: search in all places, if your part is there --> move it e.g.
for local i:=1 to store.xDim loop
   for local k:=1 to store.YDim loop
      if store.pe(i,k).cont /= void and  store.pe(i,k).cont.name ="YourPart" then
         store.pe(i,k).cont.move(YourSuccessor);
      end;
   next;
next;
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
Thank you Mr.Steffen
I have one more doubt regarding source.
How can i stop that source should not produce after 30 parts?
if you want only produce 30 parts, you can select in the source:
Time of creation --> Number Adjustable --> Amount: 30
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
Thank you very much Mr.Steffen.
It helps me a lot
Builder
Builder
Hello Steffen
I tried to follow your recommendations regarding the program.But i couldn't able to move parts from the store.
please see the attachment below. the required program is next to store as "parts_removal".
Please ask if anything is not clear
thanks once again
how do you call this method?
Steffen Bangsow
web: www.bangsow.eu
if you want to look for a MU-name , you need to write only the name and not the path (in your method:
Main_frame_red instead of .MUs.Sub_assemblies.Main_frame_red)
Steffen Bangsow
web: www.bangsow.eu
