Re: Re:parts to the store
Builder
Builder
Thank you Mr.Steffen
Sorry If wrote some bad progrms and ask you stupid questions. I have very poor knowledge about programming and i am new to technomatix.
I tried your suggestion but it still not working.
If you don't mind could you help me?
can you post your method? I cannot edit your model.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Builder
Builder
is
i:integer;
k:integer;
do
for i:=1 to store.xdim loop
for k:=1 to store.ydim loop
if store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Main_frame_red" then
store.pe(i,k).cont.move(partsfinishing);
elseif store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Anchor_winded_220_720" then
elseif store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Lower_Hfshell_red" then
store.pe(i,k).cont.move(motor_Assembly);
elseif store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Anchor_finis_220_720" then
elseif store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Upper_hfshell_red" then
elseif store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Handle_bar" then
store.pe(i,k).cont.move(final_Assembly);
elseif store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Motor_module" then
elseif store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Gear_box_2gears" then
elseif store.pe(i,k).cont /=void and Store.pe(i,k).cont.name="Flatstn_8_4_red" then
end;
next;
next;
end;
looks not bad; for calling this method you could use a generator (interval control), set as interval the cycletime of your store. The generator mill call the method ever and ever. Maybe, you need also to check, if the successor place is empty:
and partsfinishing.full=false then
Steffen Bangsow
web: www.bangsow.eu
Builder
Builder
Thanks a lot for your help and Patience.
It is working now
I tried to use nearly the same method for moving parts (Container: 1 ... Container: XX) from a store to Buffer 1. If I use the debugger, the first container moves to Buffer1. If don't use it, no container moves. Even if the first container moved, all the others rest in the storage BP_gefräst. I got following error in the debugger:
Container.PNGMaybe someone has an idea. I'm using SimTalk 2.0
Thank you!
pe is a method --> round brackets
Steffen Bangsow
web: www.bangsow.eu
Thank you, but it is still the same problem, that the container don't move. Only if I open the debugger and press F11.
you cannot use the exit control of the store, to trigger a method; the exit control will be called, if you move a MU with SimTalk from the store. So, you need another trigger for your method.
Steffen Bangsow
web: www.bangsow.eu
Thank you, I put it in the entrance control and it works now.
