Read excel file bypassing free cells by simtalk
Hi all.
How to write a method that reads into an excel spreadsheet sheet bypassing empty cells.
I want to import columns, but when the method encounters an empty cell, it pops up an error.
I am using ActiveX.
I have several columns and different rows.
Attach my current method and excel file.
Re: Read excel file bypassing free cells by simtalk
the return value is void, if you read once a sting into a any datatype, the data type of this variable will be set to string, this causes the error.
 try this:
for i:=1 to xls.range("A1:A24").count loop
		if xls.range("A1:A24").cells(i,1).value /= void then
			term1:=xls.range("A1:A24").cells(i,1).value;
			Matryca[1,Matryca.getColumnYDim(1)+1]:=term1;
		end;
   next;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hi. Thx for your help. But unfortunately still not good. The layout must be the same. So as the value in excel is in a column / cell A3 and above it is empty, then can't in TX be in the table as the first value. 01.png - excel 02.png - TX - bad 03.png - TX - should looks like.
then just let the cell empty
for i:=1 to 68 loop
  for k:=1 to 24 loop
   if xls.Range("A1:BP24").cells(k,i).value /=void then
    Matryca[i,k]:=to_str(xls.Range("A1:BP24").cells(k,i).value);
   end;
  next;
 next;
Steffen Bangsow
web: www.bangsow.eu
THX Smiley Very Happy That's exactly what it was Smiley Happy
