Read excel file with hyperlinks into tablefile
Hello All ,
Can anyone help how to load data from excel file with hyperlinks  ( to get the data in the hyperlink and not link's name)
I need to load data from excel file  with hyperlinks   that points to different sheets in the same file into tablefile that has one column with table format
so the hyper links will fill the sub table.
SG
Re: Read excel file with hyperlinks into tablefile
Hi edomk,
Is is a MUST to use the hyperlinks?
Can't you just point to this different sheets within the workbook to read the information you want?
