Read the next location of the transporter
I want to read the next location of the autorouted transporter, just like the 'Track6_1' in the figure.
But I didn't find such an attribute in Attributes and Methods List (F8) of the transporter, which has only one PreviousLocation.
Can anyone help with this?
Thanks a lot!Smiley Happy
--Chen
Re: Read the next location of the transporter
Hi ChenC,
You can use 'getRouteToDestination' when you assign the destination which will give you the list of material flow objects in a table. I think, this should help you.
Gokul
Solved my problem perferctly, thank you!
