Real-time simulation data upating in plant simulation
Hi All,
I would like to get your comments regarding real time simulation modeling.
I am using excel to import/export data from plant simulation with simulation event time clock.
 Can you advice me, How can I use real time instead of simulation event clock for real data updating?
Any example would be much appreciate it!
Thank you!
Re: Real-time simulation data upating in plant simulation
Interesting!
What application are you using PS for?
You can try the method Sleep() to create a real-time timer.
Thank you for your reply.
I am using plant simulation for real time production line. How to coodinate between real time and event time clock in PS during Simulation?
I do want to data updating (importing and exporting data)using Excel DB regulary such as every 4 hours and simulation should be triggered.. any advice?
Thank you,
Didn't sleep work?
I thought something like
is
do
    sleep(4:00:00,false);
    UpdateData;
    self.methcall(0);
end;
UpdateData should be another method where you import the data you need.
If you want to trigger Plant Simulation from an external application, you can use the COM-interface. Check the Help-pages for more details.
Your description is not entirely clear, but it seems you want to run a simulation model with updated data at a certain real-time interval. The simulation itself should probably run in a fast-forward mode, to provide a short-term prediction. Correct?
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
I am looking into COM interface at help pages. Its very helpful for my modelling.
But data importing from Excel takes time when I use COM interface..
Thank you for your comments.
