Record Production
Hi everyone,
Does anyone know how to record production per hour in a TableFile? Basically, I want to record the houly number of finished products which leave the "Drain" machine. Does anyone have an idea for me please?
Loki
8 REPLIES 8
Re: Record Production
You can write a method for this and attach it in the entrance of your drain.
This method will update a tablefile wich contains some informations about your production.
for example :
local index : integer := TableFile.indexydim + 1 ;
TableFile["Name",i] := @.Name ;
TableFile["Time",i] := EventController.SimTime ;
etc ...
I hope it helps.
O.C
Betreff: Record Production
Hello Loki,
You can create a table for the Throughput/ hour which is updated at the entrance of your drain. I have created a table called "Hourly_Throughput" for you. Maybe you can get an idea and write a method for updating. Hope this helps. Smiley Happy
Simpulse
you need to remember the old number of parts (at the start of the hour) to calculate after an hour the number of parts for this hour. This works well using a generator.
See here an example:
http://www.bangsow.de/detail_en.php?id=730
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you. It works like a charm.
Many thanks
Thanks a lot.
Hey man,
Your shift starts at 6 am. However, the tablefile does not have the value of the first hour each day. Could you please explain it?
In the example I do not record hours without output, but you can change it, delete or make a comment in the method calculate_jph:
--if jph > 0 then
	--new entry in jph table
	jph_table.writeRow(1,jph_table.yDim+1,eventController.simTime,jph);
--end;
Steffen Bangsow
web: www.bangsow.eu
