Reentry Problem
Here is a simple model, we would like to make the MU process flow to be like:
station1→station2→station3→station1→station2→station1 ...
how can i do
*for only one source each time
Re: Reentry Problem
I guess in your case
you shouldn't work with connectors
but create a user defined attribute (list , index)
for the Mus
and then call the next station in sequence and Mu move
through the current station exit method.
Re: Reentry Problem
Hi
I made a simple modle of Mu move
1. I add Buffer because of blocking
2. I add List of MU's next station
3. I add ProcCounter attribute to MU
4. I add method to count process(Which station to go)
