Remove parts from Store help
I have a created a complex simulation and I am unable to remove parts from the store. I want the MUs to be called to their specified buffer when they are needed. Can anyone help me, please?
Thank you in advance
Kbohara
8 REPLIES 8
Re: Remove parts from Store help
For example, if you add the code when the storage is empty, the entity in the buffer  can  move to the storage:
if the storage. empty =true then
 entity.buffer move(storage)
end
 BTW  I try to run your model to figure out  but, I  could not see the your created MU in each source at the class library.
Hi Pioneer,
Thank you for your quick response. I'm sorry I created a new model to post and didn't run it before posting. I re-attached the model..
Also, I tried your statement below and I can't seem to get it to work. Would you mind seeing what I am doing wrong, please?
Again thank you for your time
Kbohara
Well, I just attached a simple test model for your information.
I added a method at entrance control of store. I assumed that when stored entity number is same as store capaicty, some specified entities are moved to the buffer...
Thank you for your response but I am unable to open this model due to it being created in a newer version.
oh.. I see..
I attached the file as version 12.
Hi there,
Thank you again for your help but I still am unable to open your model. See attached error message.
It seems you are using little lower version compare with me.
Unfortunately, I don't have lower version what you are using it.
BTW,I have attached a what I did test regarding your issue.
I added  storageM meethod on store oject. the
The store capacity is 9 (x=3,y=3) and only particular storage slot is move to buffer.. just smple test.
Thank you for your feed back...I appreciate all your help!
