Replace Kanban source by a Frame
I would like to do the same thing as the Advance Demo Kanban Model of the software by using a frame (where there is an assembly object which produce new objects) as a Kanban Source.
What kind of settings should be done ?
When I'm trying to do that, I have an error message saying that the supplier couldn't find the object "requestParts".
Thank you for the advice,
Best regards,
Mylane
Re: Replace Kanban source by a Frame
Hello Mylane,
if you want to create your own KANBANsource object, this object has to support a method requestParts.
Parameter of the method are the name of the part as string and the requested quantity as integer:
requestParts( Part:string; Quantity : integer)
In this method you have to provide the requested parts.
GG
GG
