Request for a future functionality: Printing from a comment window
Builder
Builder
Hi!
It is quite interesting, that anything written in a comment window can not be printed. It needs to be saved in richt-text-format first before being capable of being printed with an external program.
I would highly prefer to have that functionality in future directly from the window instead of this annoying process.
Thx!
Mak
Re: Request for a future functionality: Printing from a comment window
Plant Simulation provides the HTML-Report for anything that needs to be documented on a screen or paper sheet. It is the most standardized way to show/print values, tables, diagrams, frames, ..., so your use case could look like this:
In the upper left corner of the report you will find the printer icon. Find the spp attached.
Always consider using the AttributeExplorer!
