Reset all user defined attributes on parallel procs
Whenever I reset my model I would like to reset a counter, which is incorporated in every parallelproc in my model. Hence, every parallel proc has a user defined attribute called "counter". Whenever I reset my model these counters need to go back to zero. Is there any way to do this without typing out every parallel proc's name.counter in the reset method? I have a lot of parallel procs namely...
The counter is an integer.
Kind regards,
Noud
5 REPLIES 5
Re: Reset all user defined attributes on parallel procs
you can use the inheritance of the parallelProc to find all children
for var i:=1 to .materialflow.parallelProc.numChildren loop
   .materialflow.parallelProc.childNo(i).counter:=0
next
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
He says that he does not recognize counter ("unknown identifier counter"). Any idea why this is the case?
Kind regards,
Noud
@Noud
 Using the inheritance capabilities of Plant Simulation, another possibility could be to :
Define a user defined method in your parallel proc class object.
 Rename it to "reset"  so that the inherited object  reset  methods will be triggered , when you reset your model.
Add the following code to reset your user defined counter attribute in the method
@.counter :=0
than you have some parallelProcs without the attribute counter, but you can check, if there is the attribute counter with isNameUnique("counter") --> false --> the attribute exists
if .materialflow.parallelProc.childNo(i).isNameUnique("counter") = false then
end
next
Steffen Bangsow
web: www.bangsow.eu
Completely correct! Thank you very much Smiley Very Happy
