Resetting attirbutes of a container in dismantle station
Hi all,
I am trying to reset an attribute of a container once it has passed through a dismantle station. It has 2 MU's attached to it which are moved to a single proc away from the dismantle station.
I have inserted a method in to the exit of the control of the dismantle station but can't get it to work.
The method I have tried is:
is
do
	@.Test:=false;
	if ?.ExitCtrlFront then
		@.move;
	end;
end;
The attribute I am trying to reset on the container is 'Test' to false.
Any help? May be simple but I am still fairly new to Plant Sim.
Jake
Re: Resetting attirbutes of a container in dismantle station
Also the entities leave the dismantlestation, so you need to identify your container e.g.
is
do
if @.class= .MUs.Container then
@.Test:=false;
end;
@.move;
end;
end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
That's great, model works exactly as intended, Test returns to false.
Thanks again Steffen!
Jake
