Re: Result is not repeating after changing the variable manually
Hello Ricardo,
the first event to be executed is the Init event.
But the problem is that some events are already computed (not executed) in the Reset methods.
We are aware that this is not a good solution. Since it is extremely difficult to change something here without changing the behavior of old models we were hesitating to make any changes.
We will look for a solution to this problem. Thanks for bringing this to our attention!
Ralf
