Return materials form workerpool buffer to worker after pause
Good morning, I have a worker which operates with different servicies. The problem is that if the worker is full when the shift ends he goes to the workerpool and leave the materials in the workerpoolbuffer but after the pause, when the worker is active again he doesnt take the materials from the buffer and continues his work (service). Anyone know how to say the worker that anytime he leave materials after a shift, next day take them and continues the interrupted work.
Thank you
Re: Return materials form workerpool buffer to worker after pause
Hello Santiago94,
You can set an Exit Strategy of the Buffer to Carry part away, the same way you do it with your regular Stations. If you want the Worker to prioritize this MU, just increase the priority on the Exit Strategy so it is always on top of the list.
