Return time in method in days
I wrote a method which returns the processing time of a parallelproc. This method returns a time which is recognized as seconds. However, I need this time to be recognized as days rather than seconds.
Does anyone know how to do this?
Noud
my method:
:time
is
n: integer;
output: time;
do
n:=?.counter;
output :=100*pow(n,-0.15);
n:= ?.counter + 1;
?.counter := n;
return output;
end;
Betreff: Return time in method in days
Hello Noud,
just devide your result by 86400 (24*60*60) and you will get your resut lin days.
Hope this helps.
GG
How stupid of me... Thanks!
