Rotation of whole layout in a frame
Hallo Everyone,
I Would like to know can we rotate all the modules inside a frame  from an another frame ? Is it Possible if yes please guide meSmiley Happy
Thanks in Advance.
4 REPLIES 4
Re: Rotation of whole layout in a frame
yes, through simtalk (s. rotate in Helpfile)
Hello Phenom,
First of all thanks a lot for the information. But I couldn't find anything directly I.e I can rotate Mus. But, Can we rotate the frame. For example, I have created a lane of a warehouse in a vertical direction. Is there any direct syntax for Changing the Whole frame in the horizontal direction (Frame has several internal tracks and connections inside it ) ?.
I would like to change the whole frame representation.
Maybe rotating manually is easier in this case.
You can select the objects you want to rotate and then
press Ctrl + T for 90 deg. rotate.
or Ctrl + right arrow or Ctrl + left arrow
Through simtalk
object.rotate(degree)
With object.RotateAroundRefPoint:=true or false you can set the rotation centerpoint
Thank you Smiley Happy
