Round up Time
Hello guys!
I need to round up value of variable which is "Time" type. Is there any way to cut off the seconds or round it up to minutes?. (I just want to get Hours:Minutes)
Thank you !
Re: Round up Time
if it just is a matter of reformatting (s.b.)
is
	s0,s :string;
do
	s0 := to_str(eventcontroller.simtime);  -- exchange eventcontroller.simtime by individual time
	s := copy(s0,1,strlen(s0)-8);
	print s;
end;
Betreff: Round up Time
And if not, this
timeInMinutes := 60 * ceil(timeWithSec / 60)
should do the trick Smiley Happy
___________________________________________________________
Alex Dilg, Consultant at SimPlan AG (www.SimPlan.de)
This post was good and/or helpful to you? Please provide some Kudos, thank you!
Thanks to both of you, but I used that second advice Smiley Happy it works perfect, but I dont understand how it works, can you explain that code a little bit, so I can use it in future projects.
Thank you again !
Best regards.
