Running multiple frames simultaneously
Hi all,
Is it possible to run multiple frames at the same time? Such that I can save time by running multiple frames at night.
William
Re: Running multiple frames simultaneously
Hi William,
you can have only one running Event Controller in your model.
But you can start as many Plant Simulation processes as you like.
This way you can run multiple simulations in parallel.
Ralf
Ralf
Thanks Ralf, same result!
