SankeyDiagram problems
I'm having an issue with my model, sorry can't share it, but when i insert the sankeydiagram and follow the instructions in the book by steffen,, wierd **bleep** starts to happen. But when I insert sankey in a new fresh model/file and follow the instructions, it works as it should. Why??
I'm still running on PlantSim 12.2.
Re: SankeyDiagram problems
Maybe it is an old version of the library, this is an internal failure; You could try to update your class library (Home - Manage Class library) --> Libraries; The Sankey Library should have the version 12.x.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Hello Tintin,
the hint of Steffen is correct.
Your screenshot does not show the original code. It seems that someone has changed the code to do his own investigations.
Peter
