Saving detailed results
I have 2 questions of which I cant find the anwsers on the forum.
1. How to save the detailed results from the ExperimentManager ( so for every experiment and every observation)?
2. How to react a certain observation of a certain experiment (for instance experiment 3, observation 7)?
The latter question is because I get a certain bug, but these never happen in the first observation, which I would be able to check.
Kind regards,
Re: Saving detailed results
Hello Jappie,
Question1:
You can use the methods of the Tablefile object.
ExperimentManager.DetailedResults.writeObjectFile("C:\temp\a1.obj")
Tablefile.readFile("C:\temp\a1.obj")
Question 2:
You can set the parameters of a certain experiment and a certain observation in the Advanced Settings Dialog (Menu Tools of the Experimentmanager) tab Validation.
Peter
