Sensors in the Air
I modified a track, change the dimensions and what not.
Then when I add sensors, the are floating above the track.
Is this a graphic flaw or can this be fixed
3 REPLIES 3
Re: Sensors in the Air
Your picture doesn't show up, at least not for me. Could you add the picture as an attachment instead?
OOTB the sensors "float" just above the running surface of the conveyor/track, but it sounds like you have a bigger gap than that?
here
yes...it has a big gap
Much better, thanks!
Did you change the scale of the track in the 3D window? Because i get similar results when I do it like that.
