cancel
Sensors on attribute explorer
Hi all. I am trying to add the position of the sensors of a track in the attribute explorer, but I can´t find the way. In the example uploaded there are a couple attributes from the track in the attribute explorer.
I realized that the path to the position of a sensor is .Models.Frame.Track.SensorID(1).Position but i cannot find the way to put this value in the attribute explorer, I cannot select the sensor in the object list of the attribute explorer. Any suggestion?
Re: Sensors on attribute explorer
Add only "SensorID(1).Position" as New attribute.
But there is no way to select such attribute cause first you should select the sensor as object and then the available attributes appear in a list regarding the object selected. The problem is that the sensor cannot be selected as an object, just the track.
Yeah... Select "Track" in objects Tab and in the attributes tab mention "SensorID(1).Position"for name of the attribute
