Sequence of worker
Hi
Sequence of worker operation is not as per defined in table file. Need to know what wrong I am doing?
Many thanks in advance.
3 REPLIES 3
Re: Sequence of worker
The machine Loading have the entrance locked.
Apparently your model is not working:
1. the entry of the loading station is locked
2. the onEntrance method of the station1 opens the debugger with an error message
3. the sequnece  index is incremented at operator arrival on every workplace
4. the self.onimportRequest method overrules the importer request
you dont need a complex programming for this sequence; the different destinations (drain/inspection) you can set in the exit control of the station
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
