Set different equip times
Hi everyone,
I have different product types with the same equip time.
Now I want to invent three different equip times.
I tried to write a code (See Pic) but its not working...
Could someone help me?
What I detected was that the type of my column is not time (see Pic2). Could this have any influence if yes what shell I do?
Best regards,
IceTea
Re: Set different equip times
you still want to change the creation table of the source?
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
I found the problem I fist have to transform the table by the source and then use the code for importing the data.
But now I have the problem that I dont' know how to remand the data to my singleproc...
If I put the list as equip time it want to transform it again and if I set it to zero its not working as well...
Can you help me?
