Set-up time triggered by MU name change only works for the first time name change
Hi:
I tried to trigger the set-up time whenever there is a model change in the station. I used two different MU names for the two product models we are producing.  I selected the Set-up depends on MU name. But it only got triggered at the first time. After that, it won't be triggered any more. I don't know why. Did I missed something?
The MUs are on the pallets which I used containers in the model. Does the container affect the trigger? How to trigger the set-up time by the name change of a MU in a container?
My PlantSim version is 13.
Re: Set-up time triggered by MU name change only works for the first time name change
you can try this solution.
And if you use container with MU in your Station, you have to change @.name --> @.cont.name in method Entrance and Exit.
Thanks.
I tried to put label on the containers, and the set-up time will be triggered by the label change. It works.
