Several workers on parallelstation
Is it possible to achieve calling several workers to work on a parallelstation? For instance, for every MU that enters a place in the parallelstation, I would like that MU to start its processing time once a worker arrives for it. Other MUs on the parallelstation which have workers during this time keep processing.
Thank you.
Re: Several workers on parallelstation
"Is it possible to achieve calling several workers to work on a parallelstation? "
- yes; assign for each worker one workplace to the parallelstation and define the number of services in the service-list
"For instance, for every MU that enters a place in the parallelstation, I would like that MU to start its processing time once a worker arrives for it. Other MUs on the parallelstation which have workers during this time keep processing."
- this is not possible, the parallelstation acts as one station, it will request all services, that you define in the service list at once; if you want to have this behavior, you need so split up the parallelstation into several (single) stations
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
