Share a training in a book and need help for something wrong
Hello Gurns:
Recently,i've been working on a training in a book.Finally,i've knocked out the code for one of the exercises in the book.But.when i operatered the model,always an error.I;m wondering about this ,and  i can't solve the problem.
If  you have time,you can see it  in the   22.spp
Re: Share a training in a book and need help for something wrong
Hello bin-sun,
The assembly stations you use (M + number) have an entrance control that changes the assembly table. You have to check the box that changes the entrance control to 'before actions'. Otherwise, station will want to set up incorrectly for a MU that will not come, since the assembly table currently has nothing for the value 'number'.
Secondly, the table 'SetupTime' has a row header that contains an underscore '_'. This should be a minus sign '-'. I hope this helped you out!
Best regards,
Nick Peeters
cards PLM Solutions
Nick Peeters
Simulation Consultant
www.cardsplmsolutions.com
Hello bin-sun,
Best regards,
Nick Peeters
cards PLM Solutions
Nick Peeters
Hello bin-sun,
Best regards,
Nick Peeters
cards PLM Solutions
Nick Peeters
only the first error:
setup --> depend on the attribute char -->
You need to set the user defined attribute char of the MUs to the values A to J.
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thanks  for your help ,it give  a lot thought.But,maybe is my mistake or  something ,I still can't make the model run.So,maybe i  should put this aside and  do something others.
Finally,thanks again  for  you specific advice
Best regards!Have a good day!
Thanks  for  your reply~  But , sor ,maybe  it's  my fault, wo can't understand your advice
Best regards!Have a good day ~
