Shift Calendar working every other week
I use the Shift Calendar to derive the arrival patterns of the patients in a hospital. On monday and wedsnesday (every other week) more patients arrive than on the other days.
Now I have made two Shift Calendars: MondayWednesday and RestoftheDays. The MondayWednesday has to work every monday, but wednesday only every other day. How do I easily model this?
I know that I can exclude dates in the Tab Calendar, but this takes many effort if the simulation takes long and is prone to errors.
Thanks in advance,
Elieke
Re: Shift Calendar working every other week
You need only one ShiftCalendar. Make a little gap before 24:00, so that you have unplanned time. Than you can use an observer in the ShiftCalendar for the attribute unplanned.
In the observer-method you can detect the weekday:
if ShiftCalendar.unplanned=false then
  local d:integer;
  d:=dayOfWeek(eventController.absSimTime);
  if d=1 or d= 3  then --Mon, Wen
     -- set your value for source.interval
  else
  end;
end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Elieke,
You can insert the dates in the Calendar part of the dialog by importing them from an external source, like Excel. This should be pretty quick.
A thought. What is the nature of a run in your case? Do you study individual days and is your system empty at the end of a day? Or do patients stay in the system for longer? This determines what kind of simulation runs you should do.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Thanks for your suggestion Steffen, it works great!
Thanks for your answer Gert.
The patients stay in the system for more than one day. I don't know how long to run the model yet, so importing from Excel still is not the way for me. But thanks for helping.
