ShiftCalendar
Hallo;
I created one model but whenever I entered shift calendar and to connect with all Process and Buffer then I don't get a summary Report.
I need Help to solve this Problem.
4 REPLIES 4
Re: ShiftCalendar
you need to set an end in the eventController; if the eventController reached the end, the summary report will be displayed
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: ShiftCalendar
Hallo Sie
can you suggest me How event controller reached the end?
Because without Shift Calendar it works
I want to know how it works in This Model
Re: ShiftCalendar
eventController - tab settings - set a end in the field end (I have set it to one day)
Steffen Bangsow
web: www.bangsow.eu
Re: ShiftCalendar
Just to add an explanation to Steffens solution: your model without shiftcalendar runs out of events to process after the 100 MUs have been produced.
If you activate the shiftcalendar, the shift calendar will endlessly schedule more breaks and shifts (which are also events), so your model never stops (unless you set a defined end time like Steffen described).
___________________________________________________________
Alex Dilg, Consultant at SimPlan AG (www.SimPlan.de)
This post was good and/or helpful to you? Please provide some Kudos, thank you!
