Showing loading and unloading time in a transporter
Hello Community,
I have a situationa where the transporter load and unload parts from various machine. The transporter stops and identify the station with the help of sensors on the track. I want to show the loading and unloading time of the transporter. Is there any way to do that ?
Thanks in advance!!
Re: Showing loading and unloading time in a transporter
you can create your own statistical data as user defined attributes, if you stop the transporter while loading/unloading you will find this value in the statistics data of the transporter ( e.g. statTranspWaitingTime), but to differ if it was loading or unloading time, you will need to record it by yourself
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thanks Mr Bangsow, but is there any attribute to delay the start of the transporter once it is loaded. is it possible to do without using any other singleproc showing the be und entladen?
if you use simtalk for loading/unloading you can use a wait command to wait a certain time, before start the transporter again
Steffen Bangsow
web: www.bangsow.eu
