Simtalk code for Animation links (Frame)
Hello, I'm currently working on a generic model.Of course, I use a lot of Frame in my model. For example, I put 10 Buffers in a frame. When I build the animation of the frame with a new icon, I create 10 lines and connect each of them to each buffer.(That's work). I'd like to know the simtalk code to access to the table of x-y coord and name of object link in order to customize it for each frame in the INIT method (Move the position of lines, delete link if it is necessary, ...) Many thanks, Regards,
Re: Simtalk code for Animation links (Frame)
look in the help: getAniPoints
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
