Simtalk to create and fill a Table Attribute (column 5) for Source/Delivery Table
I have a create a Source with Time of Creation "Delivery table".
My Table name is "ArrivePdt".
Before all, i used ArrivePdt.delete to delete everything.
I know how to change column 1 to 4 (time,object,number,name) with simtalk language (just with a loop ArrivePdt[1,k] := new value ).
BUT, i haven't find solution to change the column 5 which is a Table for Attributes.
What is the "special" name of this table ?
(I have tried to create a table with the same parameters in the same order, but it don't recognize it after...)
Many Thanks,
Re: Simtalk to create and fill a Table Attribute (column 5) for Source/Delivery Table
Hi Jer_N,
You only need to fill in this column if you want to assign attributes automatically by the Source. If so, you should use the command createNestedList to create a nested table. Check the Help-pages for some examples.
Gert Nomden
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
