Simulating Punch Press
Is it possible to simulate a piece of sheet metal going through a punch press machine subsequently creates 10 parts?
In other other words, a singleproc which is being fed by 1 MU but 10 are exiting?
Thanks in advance!
keithkduffy
Re: Simulating Punch Press
Hi keithduffy,
The quickest way is to use a DismantleStation.
Gert Nomden
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Hi Gert,
Thanks for your speed reply.
I am a novice user working with PlantSim at university.
Could you talk me through the inputs? Just the basics if you can.  (See attached)
Thanks again,
keithkduffy
